1 - 5 of 5 Posts
· Registered
I’m in the middle of converting my 2007 450 to super moto. I’m using warp9 wheels. The back fit fantastic with the spacers off the old wheel but the front has about a 1/4” gap on the left side. See pics. Should I get a larger spacer for that side? Pics of right and left attached. Thanks!
· Registered
If the spacer doesn't slide over the shoulder of the spindle then you're good to go ... but you could also loosen the r/h bolts on the top and bottom yoke and the pinch bolts bottom of fork whilst the front wheel is off the ground and spin the inner fork tube ,, if the gap goes the fork is bent ,if it doesn't tighten back up and enjoy
1 - 5 of 5 Posts
