Re read my previous post.Same problem new plug, stator unplugged kill switch im getting 126 volts from cdi box when i push starter button in and out quick ill get a burst off spark then nothing
Many owners of these bikes have found that only way to get tem to start with starter motor is by tapping the kill switch quickly while pressing start button (remember to re-connect the kill switch first)Tried all three with no spark
Are you testing with back yard test equipment like a multimeter/volt meter?Does anyone know how much voltage from cdi to coil input exiter voltage from stator
You're making progress. Tickling kill switch simulates trigger causing spark. If trigger wiring is ok you likely have defective CDI. I think your trigger is integrated into stator. You claim no spark with previous stator and coil secondary fires plug which proves ability to fire secondary. I'm fairly confident CDI is culprit. Post part number on module here on forum if possible. Will try to help
