Hey hey all waves at monitor,
I picked up a semi-rough 125 SX yesterday. I knew beforehand the clutch was 'problematic'. I can get going in first - barely. From there the engine just revs as gas is applied and will not go any faster than maybe 5 mph in any gear. I did notice some notching in the basket from looking in from the oil fill.
So, being the kind of guy to monkey around on stuff, I took off the plastics, tank, and subframe. Then I finally drained the oil (it has a generic bolt in there - I need to get a magnetic one) and saw it was grey/gray. I looked around the forums and figured it was clutch material. I smell no coolant and it didn't seem to separate after a while.
You with me still? Good
Anyhow, after draining the oil, I removed the clutch cover, pressure plate, springs, and took out the plates (all in one piece because supposedly the metal plates are both steel and aluminum and go in a certain order). I measured the friction plates and they ranged anywhere from 2.95 to 3.04 mm. That seems well within the spec from what I've read in the repair manuals (2.9 - 3 mm). Only one spring was 38.7mm - the rest were 40.x mm. The range in the repair manual is 38 - 39 mm. Maybe my micrometer was off shrugs
So, I'm trying to figure out what's going on. The greyish oil had me thinking 'def clutch'. But the specs seem to be within tolerances. Maybe the grooves? How bad does a basket have to be before it doesn't work at all? I'll try to include some pictures because ..........well...... they're just better than words sometimes lol.
The clutch lever 'seems ok'. I mean, there's nothing obvious that I can feel.
Things I have NOT looked at yet/wondering about
-master/slave cylinder
-something else in the clutch assembly (rod,pin,etc)
-How far should the push rod come out when you pull the clutch lever? I have the plates still out and the push rod is still installed. I did notice a couple of 'bluish' areas on the rod - could that be heat related?
- The one pic with the 'pressure plate' (I think that's what it's called). You'll notice a couple small 'marks'. One right by my thumb, and another about the 12 oclock position. Those are very small 'pits' in the plate. No idea what that's from.
-Oh, one more. After reading the 'aluminum/steel' clutch plate installation order, I tried my magnet on the plates - and they're ALL steel. Is that ok? I did see that the first and last plates were fiber/cork/whatever material.
Ok, I've rambled on long enough. Hoping someone out there can point an old-timey guy in the right direction
