its possible your clutch packs are well worn and in the attempt to check your bike the service guys rode it hard enough to expose that, now its exposed to you.It was recently serviced at a KTM Dealer to assess the issue with hard starting the bike, they could not figure it out, and when i received it the clutch started to slip from 4th to 6th gear when going hard on the throttle.
what to say, pull the clutch pack out and check them against new ones you buy.
1 0025050256 HH COLLAR SCREW M5X25 ISA30
4
0.82 €
2 75032006000 SPRING RING 07
4
2.53 €
3 58532080000
58532080001
* % CLUTCHSPRING 3,0X33,5
4
3.96 €
4 75032003000 PRESSURE CAP
1
112.06 €
5 60036073050
60036073150
* % HEXAGON NUT M20X1,5 7MM
1
5.53 €
6 75032018000 LOCK WASHER 07
1
15.21 €
7 75032002002 INNER CLUTCH HUB MOVABLE
1
262.43 €
8 75032033000 CLUTCH RELEASE SPRING
4
6.62 €
9 75032002001 INNER CLUTCH HUB FIXED
1
226.63 €
10 75032009000 STEPPED WASHER 07
1
7.03 €
11 75032007000 HALF-WASHER 07
2
9.62 €
12 75032001044 % OUTER CLUTCH HUB CPL.
1
796.30 €
14 75032050001 OIL PUMP DRIVE WHEEL 07
1
2.39 €
15 56532095000 NEEDLE BEARING K26X30X22ZW.KSE
1
13.64 €
16 75032017000 WASHER 26X40X2 07
1
4.03 €
17 0625060016 GROOV.BALL BEAR. 6001.2RSR C3
1
9.28 €
18 75032055100 PRESSURE BOLT 08
1
7.44 €
19 75032054200 PUSH ROD 08
1
25.64 €
20 59032065000 GASKET FOR SLAVE CYLINDER
1
1.91 €
21 0770300015 O-RING 30,00X1,50 NBR 70
1
1.36 €
23 54732064000 BLEEDER SCREW WITH CAP
1
21.76 €
24 59032061044
75032061044
* % OUTPUT CYLINDER CPL. 27MM 03
1
162.45 €
25 59032066000
75032061044
* % PISTON + O-RING + BALL 27MM
1
162.45 €
26 0015060353
0025060356
* % HH COLLAR SCREW M 6X35 WS=8
2
1.23 €
27 0015060203
0025060206
* HH COLLAR SCREW M 6X20 WS=8
1
1.23 €
28 75032112000 STEEL DISK 1,5 MM LC4 ´07
6
11.53 €
29 58332011300 LINING DISK 2,7MM FCC 02
7
19.64 €
30 58632016000 RONDELLA ANTIVIBRAZIONE SET
1
51.09 €
31 75032111100 LINING DISC CUT OUT
1
34.58 €
32 75032112100 STEEL DISK 1,5MM NITRIDED
1
16.23 €
33 75032032000 HOLDING SCREW GMB-M5X35
4
4.91 €
99 75032011110 CLUTCH KIT 690 LC4 08-14
1
297.84 €
