Hi everyone, I have a 2017 150 SX which had been sitting for the whole winter, and few days ago when I tried to start it up it wouldn't idle, giving wot from idle would cause it to literally stall. Tried playing with the carb richening it up, leaning it, by the way it has a Lectron carb, but nothing helped. Also replaced the spark plug and reeds just to be sure, and that still didn't help. So, went ahead to Harbor Freight and bought a compression tester, and after doing the test 3 times, the readings were at 70psi every single time. The bike runs great from mid to top range, even with that compression, it just won't idle and is very hard to start moving in 1st gear, have to give a lot of gas and drop the clutch to just start moving.
The bike has 45 hours on it, bought it at around 22 hours, owner claimed he replaced a fresh piston (lesson learned).
I was also confused how could the guy be changing a piston at less than 20 hours on a factory fresh KTM, it's possible but how hard do you have to ride it.
