33k miles. This bike is a blast. Twist the throttle and hold on. clean bike, well maintained, maintenance records. Title in hand.
160 hp, 140Nm of torque and a mere 238 kg overall weight, is kept in check by the most advanced electronics in the world of motorcycling. The 1290 is Happy cruising around town as well as giving Superbikes a run for their money. Power assist slipper clutch. Bosch lean sensitive cornering abs. Tire pressure monitoring system. Traction control lean sensitive. Automatic turn indicator reset. Cruise control. Clutchless shifting to 2nd thru 6 and down shifting from 6th thru 1st. Heated grips. Key fob. Electronic preload and damping adjustments. Questions email [email protected] or call 218-900-5724.
