1 - 4 of 4 Posts
my 2018 XC-F 250 won't start its full estart and when you go to start it it just does a single click
Hmmmm........a single click......
?????????? single click.....
That’s all ya got????
a single friggin click.....
son of a bitch!!!!
Maybe test your battery and perform a voltage drop test when trying to start.
Battery load test would be the next step from there. If it’s still a click maybe try connecting booster cables to a non running car. If she starts with a boost you may find your battery is bad. Check back as needed for help.
Did you leave your key on? Sounds like your battery is dead. Get yourself a trickle charger or boost it with another motorcycle battery.
If you have to replace battery from killing it too many times then you may want to look into these - you don't need to worry about it dying in the middle of nowhere.
1 - 4 of 4 Posts
