I want to inspect/replace my idler gear before anything happens. I’ve read that some 2019s might actually have the correct 6001 gear. To see this all I have to do is remove the clutch cover (not the case) correct?
if I do have the 6000 gear and need to replace it...is there a step by step write up for the procedure? Are any special tools needed?
What I have gathered is that I need to remove the right side case, remove the clutch hub assembly, the primary drive gear, and then the idler gear. Is there anything I need to pay specific attention to when removing/installing these components? (Gear positions, timing, etc).
The only parts I will need to order are: right side case gasket, idler gear, idler gear retaining clip. Correct?
thanks
thanks
