So got and 2011 RC8R last year did as about as many mechanical and electronics mods that I can. The bike is aweso,e. Now to show some love for my 1290 SAS. I did do an exhaust and fornt wheel mod for the bike. Love my 17" Super Duke wheel up front and I made a bracket and put a Super Duke GT exhaust pipe on it. I also made a set of spoked wheels for it as well. Just in case I get the urge to go off road on it. Just hard to find the time and group to do so.
As you can tell I have an RC8R and I love taking it out on some twisty roads not far from me. I five done 1 track day on it and did the California Superbike school at VIR. So for me the reason for the 1290 SAS is to be a true sports touring phenom. The 17" front really puts the Sport into S. So now after riding on the RC8R missile I am thinking it's time to do some engine performance work on the 1290 SAS. So without doing a lot of research here is my initial gut to do list,
Put a stage 3 Rotty air box on her. Remove all the SAS and SAIS systems and canister, Pull off the stock headers , knock out the catalytic honeycomb in the exhaust and then ceramic coat the entire exhaust system minus the rear drop header which is insulated. Then either keep the Super Duke GT slip on or put on an Austin racing slip on. After I am done just take it to a Dyno tune that a n handel a KTM a ECU and have them max out performance.
That is how I see it. I am thinking I can get 175 to 180 at crank with mid 150's at the rear running 93 octane fuel.
Or should I get Stage 6 with and Arrow ceramic header, and then just use maps from Rotwieller with PCV and ignition module. I can decide whether to go with the Austin racing slip on latter.
I think my way will be a lot cheaper. Rottweiler Stage 6, $1,700, Arrow header $827,
Versus knocking out catalytic and then ceramic coating my exhaust $150 plus more wrench time, and a Rottweiler Stage 3 $700 +/- and then probably $400 or so for a dyno tune, if I can get it done. So $1,300 my way , $2,600 if I do the Rottweiler Stage 6 and Arrow and .
Just think a Austin racing slip on would be the bomb.
I guess your probably thinking why not just get a 2022 Super Duke R EVO. That has popped in my mind , but at 6' 5" 270 lbs theergo on the SAS are sick and if I can get 1290 Duke performance, why not?
Give me your take on this before I cast of the bow line and I am on my way.
Sent from my SM-T970 using Tapatalk
