After a few minor changes I got to try them on the track. Switched to Pirelli SC3 and couldn’t be happier. Wear was perfect using Pirelli rep recommendation of 28R/36F hot. The shape is different too and felt very good. The rear, a 180/60 was larger in diameter so the bike gearing felt noticeably taller. I had a 42T rear and installed that. Not a big difference, but a move in the right direction. Problem, the factory chain is not long enough for the 42T sprocket. I installed a new chain which I already had and made it longer. Now, with the 42T the axle is nearly all the way back. Quite a bit longer now. I had a recommendation from a respected source that the bike felt better with the front end raised. So, I raised the front ~4mm. Basically the top of the tubes. Yes, I am repeating myself, I just want to include all the changes in one place. Reason is, all this combined, it really felt good. Very stable and easy to ride. Let me focus on my riding which is what I wanted.
with the 42T it was around 9k rpm and ~140mph on the main straight. Just about right for that track, and no shifts required in awkward places elsewhere on the track. For tracks with shorter straights, which would be most others, I could see gearing lower (44T?).
I have the KTM rear sets and moved them to highest, most forward position. I really like that. I have short legs and this was better for me.
With the mufflers I had, I felt the bike ran better with the cat installed. That, and it was too loud (yosh) or sounded odd (factory) with the others. There’s an odd thing where it feels like the bike actually accelerates just a bit as the throttle is rolled off. I noticed that multiple times. Need to discuss with a good tuner to see what the cause may be. It’s subtle, yet apparent. Some sudden change in AFR make it actually produce a bit more power for a brief instant?
After having the quick shifter tuned at the dealer, and now using Motul 7100, the shifting is much better. Not as nice as an R6 with a Translogic QS, but no longer a frequent issue.
Galfer brake pads seem to have a bit more aggressive bite. I liked them over the factory pads.
Really enjoying the bike. Next step is the lower seat for track use, and perhaps revisit exhaust and tuning options. I would like to get the richer AFR for some grunt, but also to allow engine to run cooler and to eliminate the cat.
