Hi guys i have an issue with my 2009 KTM 450 SXF when i turned on for 3 minutes the coolant started to drip out of the overflow hose from the radiator i notice that i had over fill the engine oil (all the way to the top of the sight glass) and i heard that it could blow the head gasket or the water pump seal creating prassure in the system making the coolant to rise and drip from the overflow hose in the radiator so i removed my engine oil and radiator coolant and this is how they look (see attached pictures) no signs of coolant in the oil or oil in the coolant and no smoke out of the exhaust either the only smoke came out from the crank case vent hose.
any ideas of what could be would be greatly appreciated
Thank you
Thank you
