started getting false neutral at the track last week. I have a bazzaz QS and several times I upshifted, it hung in neutral and I banged the rev limiter several times when it shifted back into the previous gear.
this didn't happen at all last time at the track and I did not work on the bike at all in between.
so I started hearing a loud valve train tick and coasted back into the pits. I loaded the bike and headed home. took it apart today and found massive valve clearance in one front exhaust valve. I removed the cam and the shim is MISSING. it is not in the head so it must have went down the cam chain passage into the crankcase?
I've got a telescopic magnet. been in the oil drain holes and all over the head. where else should I look?
