Distance "A" (5 to 7mm) is measured between the swingarm and top of chain. And measure to inner flat surface(not outer lip). Take measurement about 25mm back of lower guide.
Thanks, useful info - I've been unsure of the "flat surface vs outer lip". Chain seems like rubber, this is my second adjustment in first 1000km, and length-wise it is already at the 301 mm for 20 pins that the manual specifies.Distance "A" (5 to 7mm) is measured between the swingarm and top of chain. And measure to inner flat surface(not outer lip). Take measurement about 25mm back of lower guide.
This is one that seems well regarded and probably what I'll be going with - DID 520 VX3; not sure of the number of links - 114 I think, but you would want to verify that.Ahhh. Thank you, both.
Now that you say that, I see the arrows are pointing to the top of the chain and bottom of the swing arm in the illustration.
I've got about 3,000 km on it. Will definitely keep an eye on the chain and probably replace it. Especially now that the trails are opening back up and I'll be out in there a ways. Hope this isn't an controversial question, but any particular chains anyone likes on the 390?
Again, thanks, and I'll hopefully post some pics of the bike out in it's natural habitat soon.
Much appreciated!This is one that seems well regarded and probably what I'll be going with - DID 520 VX3; not sure of the number of links - 114 I think, but you would want to verify that.
Yes it’s 114 links.This is one that seems well regarded and probably what I'll be going with - DID 520 VX3; not sure of the number of links - 114 I think, but you would want to verify that.
