1 - 8 of 8 Posts
It seems I have a coolant leak on my 2019 SDR.... I can not even see where the leak comes from....
101500
I had a leak in exactly the same spot after refreshing mine but reusing the crush washer. Replaced it with a metal washer (and wrapping the thread in teflon) I got from a parts shop for a dime. Never leaked again.
Judging by the spray and distance, yours seems to have found a leak under pressure at the drain plug and looks to be the same problem. Probably looks more dramatic than it is.
Discussion Starter · #4 ·
Sure, it happened under pressure during a hot day, riding... "spirited"!! I'll check the washer.
The dealer called and offered me a even swap for a new 2021 Blue/Orange SDR.... and then I woke up finding my coffee cold.... :)
Yeah that's either from the drain bolt, coming out the end of the hose from the clamp not being secured proper, or a tiny fissure in the water pump cover. Either are easy to fix
Discussion Starter · #6 ·
First thing I checked was the hose - it was 100%. I guess it may be the washer... hope so. Bike is still under guarantee. Dealer said they will look into it. Nothing a big hammer cant fix! :cool:
I'm pretty sure it's the washer, because the drain plug has wear marks on it, indicating it's been loosened at least once. Maybe I'm just seeing things - and that's a reasonable assumption because I'm just a wide-eyed almost-competent home mechanic who on one occasion is able to chop an onion into a hundred pieces one-handed while drinking beer but bangs his shoulder in the doorpost moments later.
Discussion Starter · #8 ·
LOL... same here!!
1 - 8 of 8 Posts
