It sure is alive. I mixed up 2 liters premix at 40:1 and took me back to when I was 8 years old with my YZ80E. I even used a calculator lol.
Took it down the park and let it run higher in the revs, some times it cuts out or flat spots but I did get it up to powerband and felt the ex valve open.
But down low its so crisp and toey just wants to go and sounds great, different sound.
Theres a few things that need changing right away like injection timing is now probably 180 degrees out. I think TPI injects on the down stroke but now I need it to inject on the up stroke.
The small hose that goes from the cylinder base to the crankcase pressure sensor is now maybe 15mm too short because I cut about 8mm off it before the job and now the hose connects straight to the sensor without the frame that the sensor used to sit in, maybe another 7 or 8mm. Supposed to be 100mm long. This will have an effect on the way it reads.
When I first got the bike I tried a much longer hose like 20cm so as to protect the sensor from water if I swamped it but it did something similar like this so put the standard hose back on.
Idle is also hunting and sometimes revs higher then back to normal.
Totally feel the need for different injectors as far as spray pattern is concerned. The narrow stream of the TPI injectors may be intended to get fuel down out of the transfer ports to the crank against the direction of air flow but now Im injecting with the air flow and much closer to the crank so could now afford a broader finer spray pattern for better mixing and vaporisation.
Made an alloy fuel line elbow to keep the line away from the exhaust. God those clamps are ugly.
