Hello, could any one explain what are the difference between every maps that are for KTM TPI. ?
Thanks.
Herm
Maps
Thanks.
Herm
I think a factory owners manual is a good start towards an answer here. You may also find it helpful to find a service manual also. If I understood your question correctly, you want to know which maps affect motor performance and power delivery. Your owners manual has this information in graph form. You can choose power delivery range and set power valve spring according to the chart in manual. Hope this suggestion helps. Good luck to you
Hi,, thanks... but the owner manual doesn't says much or anything ... also they made upgrades or new maps but never says what is they perfomance... i wrote to KTM Factory, i ask KTM Service Center and the same,, not much answer...
Hope some one have in some explanation about each ones... i think they start at Maps 5 -6 -7-8-8R-9-9R...
Regards.
Herm.
