I HAVE 2017 KTM 690 ENDURO R ..ONLY 4000 EAZY KLM ON IT ..CHANGED OIL EVERY 1000 KLM , FILTERS AND MOTRX OIL ..NOW OIL LIGHT ON ,,I REMOVED OIL PRESURE SWITCH AND NO OIL PRESURE AT ALL.. ****..
oil light dident go out the other day , oil level was good . i replaced oil filters , cleaned both oil screans and refilled with new Motrex oil , start up , still oil light on..replace oil switch , still light on , then i removed oil switch extention tube from the top of the upper filter houing held a rag over it , started up with my thump on kill switch and no oil coming out..next will be to inspect inside filter like you sujest and see what i find.. i got the bike about 6 months ago with only 456klm on it.. ive changed oil every 500 klm an filters, then 2500 every 1000.only use Metrex.. now 4500klm..just street cruising not threshed ..Assuming you have oil in the motor and a proper oil pressure gauge, try repeating pressure test with oil filter removed and confirm filter housing is clear. I have seen people forget to remove cleaning rags before.
PS: only short test and if oil is relatively clean.
