im reassembling my engine and wanted to verify with someone
top dead center rear you line up the dots and "RE" on the cam gears
(you can see RE in the manual for this step)
then you turn 75 degrees to get top dead center front.. you line up the dots and "FR" for the front correct?
the cd manual leaves much to be desired.. it indicates line up these marks.. but the picture does not actually specify if your using RE or FR for each cylinder etc... thru taking the bike apart ktm does seem to do a good job of labeling what goes where so im assuming FR means front cams and RE stand for rear cam gears.. any verification would be greatly appreciated.
