1 - 14 of 14 Posts
https://www.quora.com/What-does-error-code-JG_1-7-7-mean-on-KTM-Duke-200-Where-can-I-get-the-error-codes-list says
If you have this error, then it might mean two things.
Your battery is low or it is not charging properly. If you recharge the battery, bike will start again . But if you again face the same issue after some time , then there is nothing wrong with your battery. It is a different problem.
The other problem is that, your relay coil would have been damaged or burnt, which in a nutshell means that the charge from the battery is not transferred to bike. So you will have to replace the relay coil.
1.2k views
1.2k views
That's a different error on a completely different bike ?
Sorry I was just following Google. I'll try to less helpful in the future :)
I found this code in my ktm Duke 200 (2019) model..after showing the code the time automatically reset.i don't know why this is happen
Hi teirra ,
I got the same error code in my duke 125 , can you please tell me what could be the problem ?
1 - 14 of 14 Posts
