1 - 2 of 2 Posts
Hello Guys
I bought used KTM RC390 2017 from one of the auctions
when I start it there is oil leaking from the chain gear I replaced the seal . thin the temperature rising up and the engine stop. so I tried to start it again . the engine starter cant cranking the engine.
when I changing the oil there are Metal shavings in oil
I decide to open the engine.
103222
103223
I removed this all Gears and nuts
So my Question is How to open the Engine Block I need to replace the Contenting Rod .
103224
WhatsApp Image 2021-07-18 at 4.48.47 PM (1).jpeg WhatsApp Image 2021-07-18 at 5.32.17 PM.jpeg WhatsApp Image 2021-07-18 at 4.48.48 PM (1).jpeg
You would remove flywheel and casing bolts and use case splitter or 3 legged puller to separate engine cases. Take lots of pictures for assembly reference. Best to source a repair manual before any further disassembly. You can easily cause a lot of damage in motor by using improper disassembly methods. Good luck to you.
1 - 2 of 2 Posts
