Hi Guys, from what I'm reading 300s are tough to get jetting right. I bought mine in a box so have no previous info. Carb is clean but runs rich no matter what I do with needle. Going to get a JD kit? But the other problem is to idle the screw is completely in. The slide is in good condition. Help?
Not sure of the particulars of your machine as I didn't notice the year of your bike. The mikuni equipped later models were sometimes tricky to get jetting right. Some guys are claiming JD kit will resolve the mikuni curse, others still curse at them. The 300 is not hard to get fueled right, but your description sounds like you have a defect. Post up year of bike and carburetor specifics(including brand)and your jetting numbers and we will try to help get this sorted. Good luck.
Sorry about lack of info. 05 300 with Keihin. It has a 40 pilot and 160 main. I know the 40 may be to big but would that make the idle screw maxed out? I'm at 3500 ft in AZ
I should have mentioned the first thing to check is inlet needle(float needle) condition and float level. The #40 pilot is not too far off for lower altitudes. Not sure at your's. I suspect your trouble may be a leaky needle or incorrect float setting. Test by shutting off fuel valve when engine is running and observe if it runs better as bowl empties out. JD jetting has any parts you need for your kehin carb. Lots of help here on forum for you as needed. Check back for advice as needed
Related Threads
KTM Forums
258.3K posts
43.8K members
Since 2007
