1 - 2 of 2 Posts
After I did the service on the ktm it switched on and worked for 20min and it will not work again. I'm changing the oil, the oil filter, the rubber dampers on the clutch and adjust the valves. Now, mostly when the throttle is holding and holding low gas, it starts firing on the exhaust. Clean the injector today, replace all the fuel filter and new fuel but still none. I measured the ignition and pick up resistance and it is correct. The phase is striving 100%. There is a spark. Does anyone have experience
Have you tried spraying a bit of fuel or something flammable into it via air intake to see if it fires?
1 - 2 of 2 Posts
