My 2016 GT is leaking brake fluid between the calipers. I took the two halves apart to clean and I realized the two halves are metal on metal with no gasket. When I put it back together, I noticed the fluid leaks from the top when I apply rear brake pressure.
I torques the two bolts holding the halves together up to 60 nm and I’m afraid to go any further. I also double checked nothing foreign was between the calipers (used brake cleaner and sandpaper to really clean the metal contact surface).
I have a bad feeling I wasn’t even supposed to take the calipers apart since the KTM don’t even see those two bolts individually.
www.ktmworld.com
Any suggestion is appreciated before I’m forced to buy new brake calipers for $160.
2018 KTM 1290 Super Duke GT Orange Rear Brake Caliper | KTM World
Shop online for OEM Rear Brake Caliper parts that fit your 2018 KTM 1290 Super Duke GT Orange, search all our OEM Parts or call at 770-748-0771
