1 - 5 of 5 Posts
I have a oil leak, am I gonna have to get a whole new one, it’s right under where u put the oil, I put jb and weld Nd it just went right through
98968
pic
It looks like your JB weld is under the drain plug area of cover. The picture shown has covered up the area of leak and would not be helpful to help determine source of leak. If the clutch/engine side cover is cracked it may be repairable by welding damaged area. If cover gasket is damaged or missing removal and inspection of cover would be required. If plug is leaking threads may be damaged or sealing gasket may be missing or damaged. You may require better study of your exact leak point or complaint for better advice here.
Yea I honestly think there’s a little crack on the cover, if that is the case nothing major is being damaged right besides me not having oil? Gonna see if I can weld it tomorrow if that’s the case
1 - 5 of 5 Posts
