Did you need the resistor kit as well ?![]()
Turn indicator Led Sequential FLOW
These supremely stylish and beautifully finished aluminum LED sequential indicators stand out for their race-style design that also exudes elegance.Kit...www.cncracing.com
This.They don't come with resistors and is in part why they are better than other led signals for the akra map.
I see. Thanks man appreciate it.They don't come with resistors and is in part why they are better than other led signals for the akra map.
Please post a pic after install.I ordered 2 sets of CNC Flow sequentials for my '23. Hope they still work after the Akra is installed. (They should.)
Can you expand on that? The CNC indicators won't fit in the stock holes? How big was the bit you ended up using?I used a micrometer to measure between the threads of the cnc blinkers, redrilled the hole and just twisted the new ones in.
If you have a Gen3, you don’t need resistors. LED indicators work directly. I’ve installed them myself.![]()
It's cheaper than it shows, because we don't have to pay VAT. And they are quick and efficient, I ordered day before yesterday and I can track through UPS that they'll be here on Monday.
It will be a bit of time before I can install them, because I have to get the Akra installed. I didn't buy the resistors to install them with the stock flash.
This is kind of a crapshoot that it'll work with a 2023. Hopefully they haven't changed anything in the ECU to keep it from working.
They are talking about the akra map and if it will detect the resistance of these indicators.If you have a Gen3, you don’t need resistors. LED indicators work directly. I’ve installed them myself.
