1 - 6 of 6 Posts
Does this washer go over the kick start mechanism shaft or the timing gear fell out when pulling the cover.
92337
30 50333030000 STOP DISK 17,2X24X1
4
1.57 €
31 0471170010 CIRCLIP DIN0471-17X1
2
1.09 €
32 0988162210 THRUST WASHER DIN0988-16X22X1
1
0.82 €
38 50333038100 SPACER BUSHING 16X23X26X6,1
1
9.28 €
3954610052000
0019080206
Korvattu uudella varaosanumerolla * % SPROCKET SCREW-AH M8X20 WS=6
1
3.08 €
40 0015060163 HH COLLAR SCREW M 6X16 WS=8
2
1.57 €
50 77033050000 KICKSTARTER SHAFT 05
1
79.73 €
51 77033051000 KICKSTART. GEAR 28-T 05
1
86.96 €
52 50333052000 KICKSTARTER RATCHET
1
66.97 €
53 77033053000 INTERMEDIATE GEAR 05
1
86.96 €
54 77033054000 KICKSTARTER SPRING 05
1
7.44 €
55 77033055000 DRIVING HUB ´05
1
4.71 €
56 50333056000 SPRING 1,4MM '98
1
1.50 €
69 50333069000 STOP MET.SHEET 4MM 125/200'98
1
10.71 €
70 54833070044 KICKSTARTER CPL. '03
1
114.79 €
71 0760172870 SHAFT SEAL RING 17X28X7 B
1
4.23 €
75 54633037000 WASHER 8MM GALVANIZED
1
4.36 €
1
11.59 €
33 0618182412 NEEDLE BEAR.HK1812 18/24/12 05
1
7.58 €
34 0402031780 NEEDLE ROL.DIN5402 NRB 3X17,8
1
1.44 €
35 77035055000 WATER PUMP ROTOR 05
1
2.80 €
36 0471100010 CIRCLIP DIN0471-10X1
1
1.09 €
380760123072
0760123073
Korvattu uudella varaosanumerolla * %SHAFT SEAL RING 12X30X7 VITON
1
5.12 €
39 77035053000 MOLDED RING WATER PUMP 05
1
5.67 €
40 77035052000 WATER PUMP COVER 05
1
33.96 €
41 0015060303 HH COLLAR SCREW M 6X30 SW=8
1
0.82 €
420015060203
0025060206
Korvattu uudella varaosanumerolla * HH COLLAR SCREW M 6X20 WS=8
2
1.57 €
43 0603061001 CU-SEAL RING DIN7603-6X10X1
1
1.17 €
99 77035055010 WATER PUMP REP. KIT 06-13
0
25.23 €
1 - 6 of 6 Posts
