1 - 4 of 4 Posts
· Registered
Today when riding the bike I was in third and rolled off the throttle due to a car changing lanes. I decided to switch lanes and hammer my throttle, when I did this I noticed I really abrupt cut in power, almost as if the ABS was stopping the bike or anti wheelie mode was cutting power. It basically startled me and got me to lay off the throttle again. This has happened a few times. Does this have something to do with ABs, traction control or anti wheelie mode??
· Registered
Yes, traction control will cut power when the rear wheel slips, and power cuts out if the front wheel starts to leave the ground. Turn all that stuff off and go hammer the throttle, but hold on tight. ABS is only working when you hit the brakes hard.
· Registered
Thank you so much. In your opinion, is the cut in power so abrupt that one would consider it jarring ??
1 - 4 of 4 Posts
