1 - 6 of 6 Posts
Hi guys, does anyone know what the dimensions of the fork springs of the RC8 are? I'm looking for OD and overall length. I believe the spring rate is .43kg/mm? Thanks in advance.
Discussion Starter · #2 ·
Does nobody know the answer to this? I'm sure at least one of y'all have a set of springs lying about to measure off... Please help guys! :D
p.s. I now know that the stock spring rate is .95kg/mm and not .43... lol
Maybe powerbrad has those dimensions....
PB?
Sent from my komputer with my brain implant
Discussion Starter · #6 ·
Hi, to answer my own question for the benefit of others, it's 38mm so the Racetech part number would be FRSP S38250xx where xx = 85/90/95... Depending on the spring rate you choose. I found this our by looking at the KTech part number for the springs, which was 38-250-9 which means 38mm OD(I think), 250mm Length and 9n/mm spring rate.
1 - 6 of 6 Posts
