1 - 2 of 2 Posts
What would the performance differences between the stock cage with boyesen pro reeds and a vforce 3 or 4 reed block be?
Bike is 2000 exc 200 with platinum pipe and fmf power core silencer.
Also can anyone help with links to sprocket gearing vs speed/gear ratio specs...
Cheers
Cheers
Your Vforce4 is latest and greatest.
some EXC models used the Vforce3 in stock form for US models. Boyesen performs well but reed life on some models is problematic due to lack of stops allowing petals to abrade on port wall. Vforce is pretty much king here. Great performance all around. Be sure to follow installation instructions exactly. You should gear your bike for it's lowest speed use in first gear. Forget your top speed number. Your buddies bike will always be faster than yours anyway:cry:
1 - 2 of 2 Posts
