1 - 2 of 2 Posts
Hi, went out today bike ran fine for first 20miles then started spluttering and would not rev above 4k ,stopped then started up ok and seemed to be better but noticed it would pull well upto 7k then if you tried to accelerate quickly above this it would splutter again, if you accelerated slowly it would rev above 7k, it's a 2016 1290 SDR with 73k miles on it, no faults showing on the dash,any ideas please, cheers Darren
Welcome to forum. If you post in the right category your chance of getting faster help improves. (In this case the 1290 Super Duke would be the one). There has been a problem with fuel pumps and their filter that causes this. But start by making sure the tank can get air to replace the fuel that is used, as if a vacuum develops the fuel will struggle to get out. (When the problem arises, just open the tank lid and see if that helps)
1 - 2 of 2 Posts
