1 - 8 of 8 Posts
I now have 920 miles on my 2018 690 Duke and I hear a buzzy noise to the right of the head stock at something like 4,000 rpm. I couldn’t find anything right away but that got me to thinking about checking all sorts of fasteners.
I have read about the steering stem nut falling off, the rear sprocket bolts coming out, probably others. What have you lost or had to re-tighten?
A few that I've had. Front axle clamp bolts, steering stem bolt, radiator shrouds on front and sides, kickstand bolts, and seat mount. Get a good torx set, and some blue locktite, and check them a couple times a year. If anything comes loose, locktite it and torque it again.
I got the Loctite and wrenches in anticipation!
Nothing structural on mine. 2013 with close to 13k miles. A few annoying buzzes though. Tank fairing and headlight mask screws have loosened. License plate buzzes like crazy on the eBay tail tidy I put on. Fuel filler cap vibrated at about 5k rpm, piece of thin foam tape on the backside of the flip up cap remedied that. Latest that I tried to track down for months turned out to be the lens in the right mirror. Tore the whole front end of the bike apart, checked all controls on the right side of the bars, nothing. Adjusted my mirror one day on the move and realized the lens was slightly loose and vibrating at certain rpm's, stopped when I grabbed it. A little super glue and I can hear every clatter in the engine again!
Excellent!
Have learnt to check everything after every race. Had the shifter fall off on a sighting lap and dangle down, came off at the shift rod on the 690. Had a belly pan bolt vibrate loose on the 990 and the shift rod around the quick shifter worked loose. Loctite is your best friend with these. KTM , Keep Tightening Mechanicals.
Reactions: todds
1 - 8 of 8 Posts
