Got pics?
Hello, I had the exact same oil leak on my 2007 SuperDuke 990. I replaced the stator, which, due to "oil intrusion" (a common theme with Mercedes Benz vehicles) was the culprit. Oil migrates between the wire and insulation and makes it's way to the brown connector.I have a US model 2007 SuperDuke 990. I've done a search on this forum and on another SD forum (which doesn't seem to be very active) and can't find much info. On this forum, one member, "3dforrest", seem to have a similar issue, but it looks like his dealer led him down a rabbit hole and never adequately addressed his issue. In any ever, my issue is this: The wires down on left left side of the battery are wetted with oil. I've done the following diagnostics:
1) The motor is bone dry, so it is is not any gasket or sealing interface on the crankcase, heads, or valve covers. It is not the wire bulkhead seal at the stator cover nor is it the gear sensor o-ring.
2) It is not the crankcase breather.
2) My oil sight tube is not cracked or leaking.
3) My oil reservoir drain plug is tight and is not leaking.
4) It is not left over residue from my last oil change as I used aluminum foil to deflect oil and prevent it from getting on the wires. On top of that I have cleaned the oil numerous times, and it keeps coming back.
5) The the three-prong orange plug on the stator wires is the top level of the leak and that connector gets filled with oil. Everything is dry above that.
Has anyone seen this before and and solved it? To me it looks like capillary action action is pulling oil up the stator wires.
Thanks.
- Walt
I'm having the same issue. I think it may be the oil filter o'ring is bad. I cleaned around mine and a few mins later I could see it getting wet with oil again. May not be but that's all I can find on mine after multiple times of taking parts off and riding down the road to get it warm and checking. If it's something else and u found the problem could u email me at [email protected] and let me no pleaseI have a US model 2007 SuperDuke 990. I've done a search on this forum and on another SD forum (which doesn't seem to be very active) and can't find much info. On this forum, one member, "3dforrest", seem to have a similar issue, but it looks like his dealer led him down a rabbit hole and never adequately addressed his issue. In any ever, my issue is this: The wires down on left left side of the battery are wetted with oil. I've done the following diagnostics:
Thanks.
- Walt
I can't bear this any longer. We all know what you mean. Here's a correctly worded reference to something being wet.the most wetted.
If u don't like the choice of words used then keep looking epse where. I mean does it really bother u that much that u had to take 10 mins out of ur time to type a msg? Grow the hell up. People like u is half the problem in the world today. Don't know how to mind ur own damn business. I bet u got picked on in elementary schoolI can't bear this any longer. We all know what you mean. Here's a correctly worded reference to something being wet.
Did you complete elementary school?elementary school
