1 - 8 of 8 Posts
Not even close.
The 890R requires TRACK mode to DISABLE the Anti-Wheelie (7 degree lift limit). All other modes have Anti-Wheelie always enabled.
So if you want to do wheelies, accidental or otherwise, the optional Track Pack upgrade is required. Otherwise, grab away..
2020 890 Duke R, 2009 R1
You can generate a tiny bit of lift with anti-wheelie (meaning you could twist the bars if you're not even-handed), but only enough that you barely feel it.
That’s the 7 degree Anti-Wheelie mode kicking in. :D
I suppose someone could biff lifting the front when steering input is essential, although the bike will stay two-wheels down.
If you do launch aggressively, you are going to get a lot more than 7 degrees of lift. I have seen a good 45 degree loft of the front wheel. Before it got there I was already dialing back the throttle.
45 degrees without being in Track mode and anti-wheelie (AW) disabled?
I can’t get the 890 to lift past the front wheel skim in 1st or 2nd from a roll with AW.
Then again, I don’t hard launch or clutch dump — which is different from merely grabbing a fist-o-throttle.
I wrote launch aggressively. So this is from a standing start. If I had done a clutch dump, it would have been over backwards. I was at about 6k, fed in the clutch pretty quickly, but not dumping it.
1 - 8 of 8 Posts
