2022 SDR Evo
Trying to remove these is a real pain. I ended up putting some small nicks in the tube trying to get these things separated from the fork tube. Now I have some very small bare metal spots on that edge. Should I try to touch them up with something? Don't want any corrosion. These tubes are aluminum right? I'm sure this has happened to someone else on here.
Yes, aluminum. Yes, i've ever so slightly nicked the tube wedging a flathead in between to leverage them down. I would not worry about corrosion, even aluminum...unless you live by the ocean?
