1 - 20 of 33 Posts
· Registered
I want to tighten my Gen 3 SDR's neck. I assume the front wheel must be off the ground and the neck must be moveable?? How do I get the bike in that position. I only have normal paddock stands. Or is there a set torque for the neck?
· Registered
If they are tapered rollers, do NOT tighten them. They need to be just pre-loaded. Just enough to remove any play where a slight amount of play is considered better than no play at all if you are not sure how to adjust them.
Even if properly adjusted, they often develope a slight amount of play after use, which is considered normal. You are trying to adjust out excess play basically.
Same as your old school Vw wheel bearings on rear drum brakes.
· Registered
Discussion Starter · #11 ·
Very interesting...
· Registered
Discussion Starter · #14 ·
I to only have paddock stands and would like to check mine since I have 3000mi on the bike now. @JWC did you do this procedure?
Yes. Loosen the bolts on the shocks ( top ones), loosen bolt on the side of the top yoke ... Torque to spec and tighten the rest... Mine is 100% now. I am also changing the oil in the damper.
· Registered
2022 SDR Evo
Did you have to remove the bars and gauge cluster like it says in the service manual or were you able to get around doing that?
1 - 20 of 33 Posts
