· Registered
Hi,
r/KTM - Top case rack
I have a top case rack for my 1290 Super Adventure S installed from the factory.
OEM part number: 61912010050
Are these racks universal as to what types of cases you can put on them? Could I buy the KTM top case or the Givi top case and not have a problem fitting it?
Seems like I would also need this rack if I were to go KTM:
KTM Top Case Carrier 790-1290 Adventure
Just want to make sure I don't buy something I can't fit or don't need.
· Registered
2021 - MT10 - 1290 SAS
My 1290 S has the same rack - When I bought the KTM top box it came with a mounting plate - the mounting plate goes on top of this rack and the box mounts on and off the mounting plate.
I am under the impression this is more of a mounting option than an actual rack if that makes sense - anything you buy mounts onto this to mount what you buy :)
· Registered
Those cases are expensive. My UnderArmor cooler bag (less than $40) has lasted over 3 years so far but has faded some. I mounted it to my 790R’s tail rack with two bolts through existing holes in the rack and holes drilled into the cooler. It won’t fit a helmet, but has plenty of room for rain gear, air compressor, glasses, chargers, and straps; but I can’t lock it.
