Pic?
I confess, I don't have a clue. Mine's a 2016, so it's different altogether.
That's quite a puzzle; somebody on here will know.
FWIW, that’s the “RACE-ON” indicator.
The manual doesn’t give any indication such would ‘flicker’ while in motion.
Not that I have been able to find...On my 2017 that light says whether your key is in range or not. It blinks twice when you're thumbing the race-on button when the key's out of range. It also blinks when engaging the steering lock. The functionality is probably the same for the 2020.
Nothing in the manual about the keyless system that answers your question?
Have you checked the key fob battery? It almost seems as if it's a recognition that the key is engaged in some manner. Yours might be losing signal along the way or something in that regard.Not that I have been able to find...
I'm guessing something must be wrong as no one seems to be chiming in that their bike does this too.
I'll guess I'll have to schedule a service.
If the key fob battery is low this light will sometimes flash indicating that it hasn't had a proper "handshake" Try changing the fob battery and see if it goes away. dont assume that the battery or "fob is new so that cant be". These fobs are temperamental and the batteries can be too.Have you checked the key fob battery? It almost seems as if it's a recognition that the key is engaged in some manner. Yours might be losing signal along the way or something in that regard.
This is correct for the 19+ as well. Leave the key out of proximity of the sensor and hit the ‘on‘ button, it’ll flash.On my 2017 that light says whether your key is in range or not. It blinks twice when you're thumbing the race-on button when the key's out of range. It also blinks when engaging the steering lock. The functionality is probably the same for the 2020.
I would disconnect the bikes main battery and try reset it that wayfirst.The battery in the fob is fresh. But the light stays on constantly. Whether the bike is on or off... I guess I'll have to bring it to the dealer.
Did you check the batter pack for an expiry date?....maybe an old new battery if you see what I mean;-)The battery in the fob is fresh. But the light stays on constantly. Whether the bike is on or off... I guess I'll have to bring it to the dealer.
I have a KTM 1290 Super Adventure R from 2019. I have the exact same issue so I am very interested to find out what solved it for you. I have tried changing the battery in the key fob and also disconnected the battery of the bike. Still the same issue. BR RuneYeah, I replaced the bike's factory battery this weekend and the light persists even after having the battery completely removed... So weird.
