1 - 7 of 7 Posts
Ok so I had a leak from my left fork, took the forks off figuring it was just the o ring and instead found that the compression adjuster had clearly been overtighten and stripped and the bolt flange bent (see pic below). So I need a new one, but for the life of me I cant find one! Help?
92253
Doesn't look like a part that's sold separately. You may have to look at a breaker or ebay for a completete fork leg.
Might be worth talking to the seller. If I had ONE fork leg and I knew somebody who needed help I would cut him a deal.
I actually ended up buying the K-tech compression adjusters. Not cheap (cost around $100 for the pair), but better fine tuning and were availabile unlike the OEM part.
1 - 7 of 7 Posts
