1290 SuperDuke Handlebar Setup Options
1 reading
293 views 3 replies 2 participants last post by  Chip0704
#1 ·
2023 SuperDuke owner, only 700 miles in after buying it as a dealer leftover. I'm 6'5" and would prefer to change the handlebar setup. While I recognize much of this is personal preference, the dealers are no help so I appreciate any concrete suggestions from those who have changed the setup.
  1. Grips- my hands are way too big for the stock grips. Want a thicker grip with no outside lip and may add Grip Puppies. Looking at ProGrip, Renthal, ODI Vans and Ouri. Inside flange or no flange? Locking or adhesive?
  2. Handlebar- would prefer a straighter bar that doesn't bend back towards rider. Lower and wider is ok too. Are there any websites that show a compare of the stock handlebar dimmensions/angles vs. the replacement options? Pro Taper Evo SX RACE Handlebar, Renthal options? Can't seem to figure out their website.
  3. Heavy weight bar ends to help reduce vibrations vs. threaded inserts?
#2 ·
Hey Chip,
You might want to take look at Apollo heated grips. I installed a set on my girlfriends 390 and was surprised at the large overall diameter (can't remember the exact size but substantially larger than the SDRs). She didn't seem to mind the difference as she was so chuffed with having warm hands.
As far as the bars, you can adjust the stock bars further forward. Should be detailed in your owners manual (definitely in service manual) but if not, it's pretty simple. Just remove your bar clamps and you'll see the lower clamp can be rotated 180° for a further forward position. There is also 2 mount holes in the upper triple clamp so you'd obviously use the front hole.
Spiegler USA has a very wide selection of handle bars (with dimensions) to help you choose a bend that'll work for you. The guys are super helpful as well so may be worth a call.
Good luck!
Cheers
-John
