Now then,
Any suggestions welcome and appreciated! Im looking to part x for a 1290 but this fault is throwing a spanner in the works!
My SD 990 2008 was sat a while in bits. I've put it back together and the display was fine at first, then the common issue of it scrambling digits started, then only the back light would come on etc. The bike runs fine.
Now, if I disconnect the battery and reconnect it the speedo works. However, it will stop working after a matter of hours.
Fixes ive already tried:
I sent the speedo off for repair / test and it is 100% fine, so no issues there.
Earth's are fine, I belive, clean and solid connection.
Fuses / relays fine.
