:grin2:@;
G'day PC1978,
Short answer is no. It's just correcting a slight final drive gearing issue if it is bothering the owner (we all have different speed limits/road designs etc). I was happy to just ride my 17Gt as a 5 speeder as it wasn't too bad, but once I was able to buy a 40t rear sprox, I found it was a vast improvement in smoothness as it allowed the engine to stay close to it's sweet spot ..... eg now 3rd is totally happy in our 60kph traffic zones and 5th is still happy at 100kph, but 6th can be used from 110kph (instead of 130).......
No need for any tuning - it's simply a final gearing adjustment to suit local conditions and a worthwhile mod for anyone with a traffic component to their riding. I still get 22km/Ltr fuel readings when I'm cruising on the motorway0
.... so it's a mechanical adjustment rather than a performance mod.
As an example, my GT is like yours, still stock, I haven't removed the SAS or charcoal filter etc etc - though I would like the extra space under the seat for puncture repair kit/tools - and it makes more than enough HP in stock trim. I've just put a K&N airfilter in (which is in the KTM powerparts catalogue so it's an official accessory) and the GT will tune itself to the filter anyway.
You may feel that you only need the 39T rear (+1) - what I know is the 40T raises revs in 5th gear at 100kph by 250rpm......(i was looking for 200rpm anyway), so the 39T would raise revs by approx 150 (I couldn't buy one to test this but others in the UK with higher motorway speed limits have done the +1rear).
Ps Be warned.... -1 front is way too much for the SDGT (=+3 rear)...... the SDGT is only slightly tall geared and only needs +1 or +2 rear max, to trim the tallness away so the motor is less chuggy in traffic (eg like a Jap gearbox..... just works without thinking about having to change to 2nd at 55kph and rev at 4500rpm).
Pps bikes are all different..... i had Caponord1200TP before the SDGT, and it was ridiculously tall geared - had to clutch it in 1st in low speed roadworks zones..... and it was a heavy clutch! It really needed -1 front and that made it a normal bike, able to ride easily in traffic, yet not rev it's head's off at highway speeds
