Well I recently moved to sea level from 6000 feet and just got back from a ride and... I'll let the photo's do the talking but its running leaner than a tit in the desert and I have no clue how to correct it as this is my first fuel injected bike. Its completely stock other than a K&N air filter. Before I moved it was running on the rich side kinda sooty but now HOT and lean. Well any help would be appreciated.
While I am going to agree with you, I am going to hesitantly suggest you've arrived at your conclusion hastily; you have not mentioned HOW you got the plug to look like that. If it was running nicely before you moved from 1800M to sea level, it will be lean now. Although I come from a caribe-perspective, and I think FI-system can compensate to some degree for atmospheric changes. If you're still in Utah, that air is going to be nice and dry; "drier than a Nun's nasty". And as you have suggested, nice and thick too. The absolute best conditions you can get for internal combustion, little wonder they hold land speed races on the Salt Lake.
WARNING: Be careful of reading plugs without having done a properly performed
plug-chop. [Link behind text] If you spend even seconds idling the Duke before shutting down, you are going to get a dry plug. That is the nature of the Duke's tune. The Duke has been tuned to run on the whiff of an oily rag.
There is a lot more air at sea level, that's how my plug looked when my bike was stock. Try the reset procedure for sure, otherwise I think there are some TuneECU map options out there for your year of engine.
Chix has provided you with what seems to be the most extensive method of fiddling with your tune. It is the most pricey too. At the other end of the spectrum are Kev's Mods. They are basic and quite effective.
But I agree; it is very likely you're gunna need more juice before rolling out onto the Lake.
