carb overflow
29K views 5 replies 3 participants last post by  desmo-kid
The float itself is connected to a tab that presses a plunger usually with
a rubber tip into the fuel inlet passage. If there is something between the rubber tip (or brass) and the passage seat, your bowl will always over flow with the gas valve on. Also if the float height is set wrong, then the gas will rise in the bowl up to the over flow passage.
