I had the rear wheel off and also did a re-gear and after getting everything all back together was lastly going to adjust the chain tension. Every other bike I have owned the deflection of the chain is measured on the bottom(below the swing arm) but the RC8 manual says to take the measurement on the top of the swing arm just in front of where it passes thru the swing arm. I am having a heck of a time getting any sort of reading there as the chain is nearly impossible to get a couple of fingers on to pull up on because of the chain guide being right there. Can you all tell me the easiest/best way to achieve this measurement? Has anyone figured out what the spec. listed in the manual equates to if taking the measurment on the bottom side of the swing arm since it is much easier to get a measurment there?
Thanks!
-John
Thanks!
-John
