2007 KTM EXC 450 RFS
I have a bit of an annoying issue I ran into this weekend that I cant seem to figure out. Hoping someone here can help me out isolating/ trouble shooting the issue. I bought this bike a few months ago, and put a few hundred miles on it. After getting comfortable on it I decided that I wanted to do a couple of upgrades/ routine mx on the bike and went ahead and did the following.
Oil change, oil filter change, air filter changed and oiled, spark plug change, new battery, added a radiator fan (oem KTM) and added a clarke 3.1g tank.
After the oil change, warmed the bike up and took it around the block, ran just fine. Went ahead and did the rest of the work listed above, all went well. On the test ride, I fired the bike up, it idled just fine and then I rode around the block. By the time I came back it was idling very high, maybe around 3k rpm. I turned the idle down and rode it again, same issue. At this point I messed with the pilot screw as well, my thought was a properly oiled filter may tweak the mixture and throw off the idle, after tweaking the pilot screw this didn't fix the issue. It was really strange.
I reluctantly worked backwards to try and isolate the issue, starting with the air filter, I replaced it with the one that just came off the bike, no change. Went ahead and took the fuel tank off (to make sure the throttle cables weren't getting pinched, also should mention the filters on the petcock looked perfect, no blockages.) and rode the bike around the block with the tank off, same issue. Thought maybe a vacuum leak around carb or boots, tried spraying carb cleaner everywhere around the assembly while bike was running, no change. Swapped battery, no change. Swapped spark plug, no change. Went ahead and reset the carb to "stock" settings. Pilot screw 1.5 turns out, and idle around 1.5- 2k rpm. I had a ride scheduled for a few days later and ran out of time to track this down. The bike runs fine when im getting on the throttle, I took it for about 100 mile loop yesterday, and it did just fine, good throttle response and didn't bog or give me any hesitation above 15% 20% throttle. However I was constantly needing to mess with the idle speed when I came to a stop on this ride. I am hoping to get some insight on the next steps to track this issue down. My hunch is a clogged pilot jet, or something in the idle circuit that is causing this hanging idle due to a lean condition. I have not gone through the carb yet, as the bike ran just fine when I bought it. Not sure what sized jets are in there, but im up at 6500ft and ride up to 12.5k regularly. I'm not sure really what I would have done to mess with the idle this bad, but its annoying and want to get it fixed.
Thanks for any info or ideas you have!
