I recently purchased a 2015 superduke 1290r and it is having troubles starting. Most of the time it does not want to start. When you turn the bike on the fuel pump will run and everything turns on like normal.
When you press the starter button it is almost like the starter button is broken as the bike won't even try to turn over most of the time. I took it apart, cleaned it, and tested the continuity. I tested the fuses and all have continuity. I also replaced the starter relay solenoid for a brand new one (just in case that was the problem). I do know the kickstand kill switch sensor has gone bad, but it still doesn't want to start even in neutral with the kickstand up. I also think the neutral sensor is bad because the light will not illuminate on the screen even when in neutral. Is there another sensor or part of wiring that could cause this issue?
