Hi guys,
Wanted to share a great site for cross-referencing KTM parts. It can cut down on lots of research. Just plug in the part number in the search box and it will show you all the bikes that share the same parts. Sometimes is crazy to see how many bikes one part fits!
https://www.ktmonlineparts.com.au/part/ktm/54839031700#content
Also, just wanted to share a story about lost spark and and the epiphany working on my Honda 400EX back in high school. I had stripped down my quad to powder coat the frame. Got it back and put back together, but it only ran for around 3-5 minutes and shut off. No lights, no spark, no neutral green light, nothing. Wait around 5 minutes and everything was back to normal, but when I started it again, the same thing happened. Stumped as could be. One day I was just going around touching stuff and I moved the exhaust and saw a spark from the bolt going to the frame, then AH HA! that's when I realized the stator was generating power but it was not a complete circuit because after powder coating the frame, I removed the ground for the motor. I ran a cable from the engine mount to bare metal and BAM, all is good! Was so proud of myself
My last no spark issue on the 2000 KTM 250EXC was a bad CDI box. I had a small crack in from the forks hitting it from a fall. Luckily I was riding local when it lost spark!
