I found another radiator leak, yop rail other side and it only spewed under pressure. I removed the tank to access the radiator and after putting everything back together the fuel pump isn't charging when I turn the key and I've gotten the two codes above. I'm sure I plugged the 2 wires in under the tank, reconnected the fuel hose and am confused?
