How to use KTM Connect?
11K views 10 replies 4 participants last post by  Cracker
I have registered my new 3.0 EVO on the KTM Connect app...
I have connected my phone to the bike by bluetooth...
I have downloaded the right map...I set the destination...
But I don't see anything on my dash...
How does KTM Connect work? Some help?
Thanks a lot
it's there what it doesn't do is come up full screen it's in the bottom part of the menu bar on the screen scroll past the heated grips sub menu untill you get to the navigation part it shows turn by turn in the bottom left corner it's pretty crummy though.....your best bet is to do what I do......get yourself a set of earbuds....I only use the left earbud.....make sure they're paired with your phone and in the Nav App settings is a sub menu Language and sounds and in that another sub menu Instructions and Sounds make sure you got Voice instructions ticked.....get your destination setup on the Nav App press start then stick the phone in your pocket and listen to the Nav turn by turn it's much easier than looking at the pretty hopeless turn by turn display especially if you don't want die
