Is 90 PSI on compression test really bad?
2.5K views 12 replies 6 participants last post by  K1LLA
I'm thinking 90 PSI would hardly start and run.
You can use select fit base gaskets to adjust squish and compression slightly or simply pop for high compression cylinder head. PV adjustment would be required for best result. See Slavens Racing video for correct adjustment instructions.
Reactions: K1LLA
